mcerd1
| posted on 14/6/12 at 09:25 AM |
Bearing strength of bolts - oversized holes ?
one for the structural engineers...
according to bs 5950 if I've got an M16 bolt in a std. oversized hole (20mm dia) then the bearing strenth of the connected parts is 0.7* that of
the std. clearance hole
....so what happens when you end up with a 22mm hole instead ?
I'm fairly sure its strong enough, but I cna't find anything in the codes to back this up yet
(and this customer will insist on seeing the calcs)
Help!
-Robert
iank
| posted on 14/6/12 at 04:46 PM |
Software engineer answer, buy some 22mm bolts and pretend you always intended them to be that size.
Not useful, but an easy way out potentially.
Anonymous
mcerd1
| posted on 14/6/12 at 10:03 PM |
unfortunatly its a 22mm hole on one part (the correct size for an M20), but some numpty has made the hole in the other part too small
| posted on 15/6/12 at 12:45 PM |
Fit a collar in the hole, bodger's answer.
