ash_hammond
| posted on 24/10/16 at 09:57 AM |
OT: House Alarm Question.
Morning Fellas.
We moved into our new (15 old years old) house on Friday. The old occupier gladly supplied the alarm code to the estate agents with the keys. When we
entered the property for the first time the alarm was set. So we entered the code and the alarm disabled. There are two key pads to the system, one
at the front door and one at the back door and various window and PIR sensors dotted around.
A few hours later the alarm started to sound, once again we entered the code and the alarm reset and disarmed. This happened several times, we
eventually worked out that when either the light in the garage or utility was switched on it set the alarm off.
I know the alarm has main power and a lead acid battery in the main control box and one in the bell box outside. Fortunately, its the same alarm as
our old house, so I do know the system a little. When the alarm is triggered by the light switch you can only hear the keypad going off, the alarm
outside is silent. I'm assuming the following is happening.
1) The alarm has never been serviced and has a very old and totally dead batteries in it.
2) When the light is switched on this causes a power fluctuation on the lighting ring main, which I'm assuming the alarm is wired from with it
being low amp rating.
3) The alarm takes its primary source of power from the battery which is now dead and the uses the mains feed to recharge the battery. Hence why we
cannot hear the alarm outside.
I think the first course of action (for the cost) is to replace all the batteries in the system, check all the PIR sensors look in good working order
before calling out the engineer. I have a feeling the previous owner knew about this, every time we went to look at the house, the garage light was
always switched on when no one was in the garage. Alarms bells are starting to ring here
The alarm is a Veritas R8 if anyone else knows the system.
Does my level of investigation sound sensible?
Ash
.: www.mac1motorsports.co.uk | www.m1moc.com :.
r1_pete
| posted on 24/10/16 at 10:08 AM |
Sounds sensible to me, the dead battery will open up susceptibility to power fluctuations.
Also, most if not all mains fed alarms advise a dedicated supply from the breaker board (fusebox) it may be that yours is piggy backed off the garage
light feed, would be worth checking the feed and correcting.
ash_hammond
| posted on 24/10/16 at 10:24 AM |
Thanks Pete. I'm going to assume it is piggy backed too, I cannot see switching the might in creating that much electrical interference try it
triggers the alarm via the air. Some thing must be hard coupled.
If it is interference, I'm going to started holding my micro meals to the ceiling where the cables are and see if they cook.
gremlin1234
| posted on 24/10/16 at 10:52 AM |
can you set the alarm without the power monitoring part.
ie page 4 of this document
http://www.click24.co.uk/support/intruder-alarm/Veritas%20R8%20User%20Guide.pdf
To Set the System With a Power Fault ...
ash_hammond
| posted on 24/10/16 at 12:06 PM |
Thanks for finding the manual, it was the next step. I'd forgot you can test the sounder and other bits individually. I can test each component
and try and nail things down.
| posted on 24/10/16 at 12:35 PM |
Check the battery fuse while your on, they blow when the batteries go south...
ash_hammond
| posted on 24/10/16 at 05:43 PM |
I've checked the external sounder and that works fine.
All the glass fuses inside the main alarm box are fine.
The battery in the external sounder seems OK as it ran with no mains or battery connected
There is 240v to the unit.
The lead acid battery was installed in 2002 and sounds like a box of rocks. It was on its side and looks like itnhas leaked and the terminal are all
fuzzy.
Ive ordered one so this is a fair starting point.
ash_hammond
| posted on 26/10/16 at 06:47 PM |
No joy. A new battery and all the fuses checked, it still does the same. I'm going to see if I can find the power source at the weekend. If it
is hooked to the lighting ring main unwire it and add a plug on to and run it off of an extention tempery to see if that fixed it.
Any other suggestions?
gremlin1234
| posted on 26/10/16 at 07:34 PM |
are the lights 'fluorescents' with starters? they generate a huge spike as they start. tungsten also do a similar thing, with a huge dip
(inrush current) as they light
craig1410
| posted on 27/10/16 at 01:05 AM |
I've got the same alarm system and installed it myself about 11 years ago. It's been super-reliable although I did replace the alarm
system battery a year or two ago. I think the LED on the control box started flashing or something and when I looked into it, that was a sign of a
failing battery.
If the internal sounder is sounding then that might be caused by the tamper protection being triggered or alternatively it may be caused by the bell
box which has its own battery usually and is self-activating if it loses connection to the alarm control box. Normally when you get an alarm
activation, you type in your code and press the reset button. However, before you press the reset button, look at the LED strip as it should show the
'zone' which caused the activation. You should be able to then trace that zone. One of the zones is designated as the 'tamper'
zone if I recall correctly.
I've got both the user manual and the installation manual for the veritas system so let me know if you need any more help. I'm not an
alarm expert or anything but I am an electronics engineer and this system was relatively straightforward to install and configure as I recall.
HTH,
Craig.
