Author: Subject: Anyone recognise this unusual thread form?
Rorty
posted on 24/1/05 at 03:35 AM Reply With Quote
This morning I received a tie rod end from a US client which I intend to use in his car, but, unusually, the male thread measures 11/16" x 18 TPI. I haven't come across this size before.
The nearest sizes I'm aware of are 5/8-18 which is a UNF form and 11/16-16 which is also UNF.
I searched the web, but can't find anything relating to this particular thread form.
I can't remember what vehicle my friend said the TRE is from, but it's a new Moog joint and the part # on the box is ES445RL.
If I can't find any data on this thread form, I don't fancy my chances of finding many jam nuts or more importantly, a tap to suit it.
Can anyone shed any light on it for me please?
As it's 18 TPI, I may be better off re-cutting the threads to 5/8-18. At least there will be jam nuts and a tap readily available, though it would mean any replacement TREs would have to be similarly re-threaded.
Cheers, Rorty.
gazza285
posted on 24/1/05 at 06:17 AM Reply With Quote
As used by Ford and Massey Ferguson according to this.
Another case of manufacturers making their own thread sizes up probably.
Rorty
posted on 24/1/05 at 06:33 AM Reply With Quote
Wow. Thanks for the confirmation, I thought I was going mad. I wonder what the chances are of finding a suitable tap.
Cheers, Rorty.
posted on 24/1/05 at 10:22 AM Reply With Quote
My sisters' ex used to work at a firm in Chesterfield called Kitchens who made parts for Massey tractors. They closed in 2003. He said they used some weird stuff.
Rorty
posted on 24/1/05 at 12:39 PM Reply With Quote
The options with that weird TRE were limited, so I've suggested a different one with a more common thread.
Thanks everyone for your input.
Cheers, Rorty.
drmike54
posted on 24/1/05 at 03:58 PM Reply With Quote
Shouldn't everyone make their cars with tractor parts?
Started Welding the chassis!!!!
gazza285
posted on 24/1/05 at 05:59 PM Reply With Quote
Good enough for Aston Martin after all.
gazza285
posted on 24/1/05 at 06:03 PM Reply With Quote
My Father made a tap for me when I was stuck once. He turned it out of a bit of a six foot prybar I have in my van, didn't turn too nice though, then he ground in some flutes. It worked fine for the two holes I needed it for. It was a 3/4 unf left handed, to buy a tap it was getting on for £90.
Rorty
posted on 24/1/05 at 09:03 PM Reply With Quote
I've made some temporary taps from high tensile bolts by making flutes with a grinding disc and then re-hardening and tempering them.
Further research reveals the 11/16-18 thread was quite common some years back. It does seem to have its roots in the agricultural industry, though some trucks used it also.
There may well be a tap available to suit it, but it all seems a little too dificult and I'd imagine the tap would be expensive.
Cheers, Rorty.
Alan B
posted on 24/1/05 at 09:52 PM Reply With Quote
Here's one.....
http://www.mcmaster.com/
search for page 2239
about 36 us dollars
[Edited on 24/1/05 by Alan B]
Rorty
posted on 24/1/05 at 10:16 PM Reply With Quote
about 36 us dollars
Alan to the fore! That'll save some footwork and lets me continue with the process.
I've emailed my customer and he's ordering one of those taps right now. Seems they're in stock too. Thanks M8.
Cheers, Rorty.
The Shootist
posted on 25/1/05 at 02:41 AM Reply With Quote
I use McMaster Carr at work.
They have just about anything, and almost always in stock.
A friend at UPS (United Parcel) told me they have a 4 block long warehouse in Atlanta. UPS just drops off a dozen or more trailers every AM and picks them up in the PM.
Rorty, any decent machinist should be able to thread a hardenable rod on his lathe, mill flutes, and then harden it with a torch. My 1940 Machinists Handbook has a how-to for just such occasions. But since this is an available tap the point is moot.
