Author: Subject: Cav Exhaust
Chris_R
posted on 8/3/05 at 07:22 PM Reply With Quote
Cav Exhaust
The centre box on my cav has gone. Does any one see a problem with ditching it for a straight section of pipe?
[Edited on 8/3/05 by Chris_R]
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Ben_Copeland
posted on 8/3/05 at 07:24 PM Reply With Quote
My cav box went too when i had the GSI, put a straight section in, went better and sounded even better
Ben
Locost Map on Google Maps
Enter Your Details Here
Chris_R
posted on 8/3/05 at 07:33 PM Reply With Quote
thought you'd be the first. Saves welding on a flange and salvaging it. No MOT probs?
Ben_Copeland
posted on 8/3/05 at 07:35 PM Reply With Quote
Only if the welds leak! and its tooo noisey
Ben
Danozeman
posted on 8/3/05 at 07:51 PM Reply With Quote
Go for it mate. I did it on me calibra goes better..
Dan
Chris_R
posted on 8/3/05 at 07:55 PM Reply With Quote
guess that's that then. Easy pleased.
clbarclay
posted on 8/3/05 at 08:51 PM Reply With Quote
Not sure about the center box, but i've known the back box of an SD1 replaced for a length of straight pipe.
It was enough to fool one person into thinking that it was the v8 model when it was only a desiel.
Chris_R
posted on 8/3/05 at 10:31 PM Reply With Quote
My dad had 3 SD1's in succession, all 3.5 V8's. When the exhaust went on one of those you knew about it.
Chris_R
posted on 12/3/05 at 06:10 PM Reply With Quote
Just finished butchering the exhaust and it sounds ok. After what date are cats mandatory? Think it might go the same way if poss.
posted on 12/3/05 at 08:28 PM Reply With Quote
If the car was registered after 1st August 1992, then it will be given a cat test (with a few exemptions, relating mainly to imports). It does not have to physicaly have a cat, but chances are it won't pass the test without one.
Chris_R
posted on 12/3/05 at 08:50 PM Reply With Quote
bummer, mines a 94. Cheers Mike.
phelpsa
posted on 12/3/05 at 10:50 PM Reply With Quote
My mum had a cav which lost a section of exhaust. I think the most noise came from the pipe dragging along the ground
