James
| posted on 17/3/05 at 03:45 PM |
Replacing Hydraulic Tappets- MK2 Golf
Seems the head gasket may have gone on my MK2 Golf.
Whilst I've got the head off I thought I might aswell replace the rattly tappets.
I bought a whole tappet set but I'm not sure if I need to replace them as a set or just the dodgy ones?
Also, do they 'pair' up with the camshaft in such a way that replacing the tappets means the camshaft needs to be changed? Or does the
wear not happen like that?
Thanks for any information!
James
[Edited on 17/3/05 by James]
- Muhammad Ali
ned
| posted on 17/3/05 at 04:11 PM |
i don't see why you can't replace them individually, though if you have the set and are doing it you might as well do them all at once as
you'd need to remove the cam anyway to get at them presumably?
all imho
Ned.
[Edited on 17/3/05 by ned]
beware, I've got yellow skin
| posted on 17/3/05 at 06:42 PM |
Might be worth putting a litre of auto trans fluid in the oil for a few miles before you lift the head it has been known to free sticking tappets but
don't leave it too long a it has quite a lot of sulphur in it..
