Author: Subject: B&Q Welders
lewis635
posted on 21/3/05 at 06:17 PM Reply With Quote
B&Q Welders
B&Q sell a 130 turbo mig for £149.99, this seems to be a good price. i think they are made by cosmos. Has anybody got one of these and are they any good?
chunkielad
posted on 21/3/05 at 06:41 PM Reply With Quote
I got one and it welds well. Only prob is using it gasless it sticks lots. With gas perfect.
Triton
posted on 21/3/05 at 06:43 PM Reply With Quote
Don't waste your money because all welders like that are rubbish and certainly no good for making a chassis.....go to a welding suppliers you will be surprised how cheap you can get a REAL welder for.
posted on 21/3/05 at 07:04 PM Reply With Quote
Rebadge SIPs--- on the the hobby SIPs feed mech is under engineered, the plasic holder for he presure roller isn't a great design and the feed motor looks like it came straight out a Scalectrix car. The SIP controls also take a bit of figuring out. You will get irritating faults that require fiddling with to get it to work properly -- on mine the fan came off its shaft after about 6 hours use -- easy to fix but it shouldn't have happened.
However they weld OK --- gasless wire works fine with the DP models provided the polarity is swapped.
The Clarke "Red" range are much better if buying new that is what I would go for. Ferm also have good welders in this size range.
RogerM
posted on 21/3/05 at 08:39 PM Reply With Quote
I have a Clarke 151T Mig and that has served me well for more years than I can remember.
I only really use MIG for mocking up and rought work now but I have run alot of wire through it in the past and it has held up great. If I was going to recomend a MIG welder that would be it. TIG is the daddy but not cheap, a bit more of a learning curve and slower .... nothing looks better though and penetration is a gaurentee.
The only real difference between the red and bue clarke range is that the red has a hinged door and the blue has a slide off panel ....... woooppppiiiieeee.
Buy the blue and put the money you save to a decent helmet.
lewis635
posted on 21/3/05 at 09:17 PM Reply With Quote
okay so clarke seem to be the preferred choice.
anyone know of a "cheap" supplier.
Thanks for all your opinions
flak monkey
posted on 21/3/05 at 09:29 PM Reply With Quote
AFAIK machine mart are the Clarke people...
Sera
http://www.motosera.com
Triton
posted on 21/3/05 at 09:59 PM Reply With Quote
Ok if you want to weld cheese and that's about it....they also do spanners for undoing and doing up the odd bit of cheese too.
MikeR
posted on 21/3/05 at 11:25 PM Reply With Quote
Ouch Mark you're being a bit harsh tonight!
Marchine Mart do the vat free days - good time to buy from them but you need to be 'invited'. So go along buy something and get on the mailing list.
Personally I've got a clark 151 (the blue one) and think its great. I'm not the best welder on earth but it does the job for me and was the right price.
posted on 21/3/05 at 11:31 PM Reply With Quote
machine mart is a great place for making you think 'sh*t, i didnt realise that stuff was so cheap...'
like drills for £11 - probably crap but you just have to bear the quality in mind when using one. And stuff like jacks and stands etc, dead cheap.
marshall
posted on 22/3/05 at 06:29 AM Reply With Quote
if you just need a welder for making the chassis look for a second hand one you can get a good one cheap
lewis635
posted on 22/3/05 at 09:15 AM Reply With Quote
Thanks for all the advice, the chassis is already built so i just need the welder for suspension brackets and other little bits, that is why i was looking for something cheap.
posted on 22/3/05 at 09:22 AM Reply With Quote
Pays to shop around last month I was thinking of buying a sheet metal folder and a sheet metal/bar shear --- surprisingly Screwfix were a lot better value.
clbarclay
posted on 22/3/05 at 10:34 PM Reply With Quote
Machine mart quality is quite vairable between different products.
200amp arc welder from them, give it a few years use and it won't even look at a 4mm stick.
On the other hand I have no complaints about thier tool chests, other than how other manufactures/distrobuters charge so much.
