Author: Subject: AT PSU pins for electrolysis
Dillinger1977
posted on 18/4/05 at 12:30 PM Reply With Quote
hi chaps,
just found an old AT (i think) PSU lurking in a cupboard and fancy putting it to use in an electrolysis setup.
can someone tell me which pins to use for the positive and negative to go to the tub?
the motherboard plugs:
thanks!
-Rog
andyharding
posted on 18/4/05 at 12:36 PM Reply With Quote
Usually:
Black is 0v
Red is +5v
Yellow is +12v
stephen_gusterson
posted on 18/4/05 at 07:58 PM Reply With Quote
if you want 12v, take it from the disk drive leads. those ones are the motherboard leads - 12v on there too, but easier to ID from a drive connector
atb
steve
ps
if the fan doesnt run, it signifies its not powered on - you may need to connect two other wires together - i dont know which ones off hand - someone will tell you tho.
ChrisW
posted on 18/4/05 at 08:19 PM Reply With Quote
Not on AT Steve - it's only the newer ATX supplies that have a PS-ON wire.
You may need to load up the 5v line though to make the PSU work properly. Something like an old indicator bulb will sort it.
Chris
stephen_gusterson
posted on 18/4/05 at 09:55 PM Reply With Quote
absolutely right Chris. Been a bit since Ive seen an AT psu, and didnt notice the missing X.
atb
steve
