Author: Subject: How much gravel?
Northy
posted on 6/5/05 at 10:44 AM Reply With Quote
How much gravel?
We've got a small area of grass at the front of our new house thats a pain to cut. I want to dig it up and gravel the area, but I'm having a hard time working out how much gravel I need. How do I work it out?
Graham
posted on 6/5/05 at 10:48 AM Reply With Quote
Length x width x depth required?
I'm sure that if you tell the supplier how many cubic metres you require then he can tell you how many tons that comes to (assuming that he sells by weight not volume)
DJ
Wadders
posted on 6/5/05 at 10:55 AM Reply With Quote
to give you an idea, about 20 barrow loads is a ton.
Al.
omega 24 v6
posted on 6/5/05 at 11:15 AM Reply With Quote
or 1 off 1ton barrow load
flak monkey
posted on 6/5/05 at 12:18 PM Reply With Quote
Dont forget to put some kind of matting down to stop weeds growing through the gravel (saves a lot of time). We put some down when we gravelled around the edge of our house, and it works brilliantly. Its like thick black fabric, so it still lets the water drain away. Cant remember what its called though.
Sera
http://www.motosera.com
clbarclay
posted on 6/5/05 at 12:54 PM Reply With Quote
Don't forget subsidence. The depth of gravel will drop as it settles down. This means more gravel will be needed depending on how firm the ground is to start with. The gravel wants firming down well as it is laid, too reduce the ammount it subsides latter.
Northy
posted on 6/5/05 at 01:09 PM Reply With Quote
Just been to price it up, £180!
Just because the previous owners used posh stuff under the window and we wanted to match it up. I think I'll cut the grass
Graham
posted on 6/5/05 at 04:02 PM Reply With Quote
Use Pea Shingle from Wickes very cheap --- then sprinkle on a few bags those coloured glass beads that pound shops sell -- looks very avant garde but not obtrusive
Most anti weed matting will stop dandelyons and the like but some fine rooted weeds can put roots through it ---- to prevent this in adition use black polythene sheet (heavy duty bin bags) with with gaps to allow for drainage.
