mookaloid
| posted on 7/8/05 at 06:54 PM |
Punto Sump replacement
My partners punto sporting 1.2 has sprung an oil leak - the sump has rusted through!
Anyone ever come across this before and is the sump easy to remove with the engine in situ for welding up?
Thanks in advance
Mark
| posted on 7/8/05 at 06:57 PM |
Before welding up check out the cost of a new one, easy to remove/refit but usual crap Fiat steel/rustproofing.
MkIndy7
| posted on 7/8/05 at 10:48 PM |
Can't help with a Punto but I know mine for a Fiesta would have been about £40 for a new sump.
That had rusted badly from the outside through and was helped along by big dip closely followed buy a big bump in the road!
Erm no nicer way 2 put it but it was a completed BASTARD! to change! Being FWD the exhaust was in the way, starter motor had to come off as
there was bolts you couldn't get to behind that etc, took about 4hrs or seomthing daft doing it on the driveway on axel stands.
Good Luck!
VinceGledhill
| posted on 8/8/05 at 08:40 AM |
Giz a shout next time mate. I've got a double garage / pit and air tools....
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
theconrodkid
| posted on 8/8/05 at 03:12 PM |
doddle to replace and cheap from fiats,bout £30 if i remember right,they are allways rusting through,get the proper sealer from fiats as well,no
gasket used
who cares who wins
pass the pork pies
mookaloid
| posted on 8/8/05 at 03:15 PM |
gasket used
Was it some time ago? I've just been quoted £76.85 plus VAT or was the £30 just for the sealer?
Good to know it's not such a difficult job though..
Mark
Jeffers_S13
| posted on 10/8/05 at 09:20 AM |
Ive heard its a problem with them aswell. My gf's is looking like it may finally go in the not too distant future. Seem to require a lot of
attention these little Puntos, what with cambelts, rear bushes, cam cover leaks...etc
mookaloid
| posted on 10/8/05 at 09:23 AM |
New sump has just arrived
got it from shop4parts.co.uk about £60.
I know what I'll be doing tonight
[Edited on 10/8/05 by mookaloid]
| posted on 10/8/05 at 06:12 PM |
Hope you got the sealant as well !
mookaloid
| posted on 10/8/05 at 09:51 PM |
I did
