Ian Pearson
| posted on 12/10/05 at 09:36 AM |
Cordless Phones
The cordless phone I have is a BT branded digital job. It's absolutely useless. We've moved to a house that has thick walls, which have
rendered it worse than useless! It's meant to have a range of up to 100m (line of sight), but starts to lose signal strength after about 5m. Any
advice on phone's with greater signal strength/range.
Regards, Ian.
CommanderAce
| posted on 12/10/05 at 10:51 AM |
You want a Switch DECT phone
Check out this review.
DaveFJ
| posted on 12/10/05 at 11:47 AM |
DECT phones don't have a great range but you can buy 'repeaters' which will double your range.
Dave
| posted on 12/10/05 at 08:14 PM |
I had trouble with BT analogue cordless phones going belly up -- 2 different sets and types in the end I decided the quality was lower than whale
poo.
clbarclay
| posted on 13/10/05 at 02:51 PM |
We had a BT digi cordless and it kept playing up, speaking to a BT engineer, found out that it was the same model as the ones BT gave free with new
lines and the engeneers spent a lot of there time just replacing the phones.
Curently use an old faithful anolog, but even that is not infalable, we also have an old rotory dial job (you know the sort that come in a hideous
colour of green plastic) that works in any conditions, particualy when theres a power cut.
