Snuggs
| posted on 22/12/05 at 06:02 PM |
Automatic transmission fluid
I need to top up the power steering fluid.
The manual states that it needs Dexron II D but the sticker on the resevoir says Dexron II E.
Is it OK to mix II D and II E type fluids or do I need to drain and refill the system.
ps The fluid already in is red if this helps.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
DEAN C.
| posted on 22/12/05 at 06:38 PM |
You can mix most ATF oils Ok,even Dextron I and Dextron II mix fine with no problems.
Some manufacturers specify a minimum of Dextron II sometimes, but thats mainly the latest type auto boxes.
I dont think your P.S. pump will notice the difference.
Once I've finished a project why do I start another?
| posted on 22/12/05 at 07:19 PM |
Dextron II is Dextron II fine no problem
The rule is don't mix Dextron non Dextron types.
Snuggs
| posted on 22/12/05 at 08:59 PM |
Cheers guys
Clive
