theconrodkid
| posted on 11/1/06 at 05:58 PM |
rebar and reet expert wanted
right,got a little job on,need some specs for re-bar and concrete to be used,its only for a section or road so nowt too complicated,this anyone,s
feild?
who cares who wins
pass the pork pies
mookaloid
| posted on 11/1/06 at 08:26 PM |
What do you want to know?
I have a city and guilds in concrete technology....
Not used it for a while tho
Mark
theconrodkid
| posted on 11/1/06 at 09:15 PM |
done a job where road collapsed,its called "swallow holes",water has washed away the gravel/soil etc.
we have to fill the void with X hundred tons of concrete and use rebar for below the road bed.
concrete supliers need to know the spec and steel supliers need to know what spec for the re bar grid,any ideas?
who cares who wins
pass the pork pies
| posted on 11/1/06 at 09:17 PM |
Chuck some old bike frames in, it'll be alreet.
theconrodkid
| posted on 11/1/06 at 09:21 PM |
one family threw some fridges down the hole when their kitchen went south for the winter
who cares who wins
pass the pork pies
mookaloid
| posted on 12/1/06 at 02:57 PM |
Not easy without seeing it, but I would probably fill it with semi dry lean mix suitably compacted, to a level about 120mm from the finished surface,
then lay 80mm concrete block paving to finish.
If it sinks a bit you can just lift the block paving out, add a bit of fill then relay.
If you use a concrete slab, and the sublayer sinks then the slab can break up and cause damage to vehicles passing over it.
HTH
Mark
theconrodkid
| posted on 12/1/06 at 03:13 PM |
k cheers for your help mark.see what gives
who cares who wins
pass the pork pies
