James
posted on 14/4/02 at 05:54 PM |
Registration and Number Plates
When you get the car SVA'd and then registered does the SVA engineer check the engine number against the log book of the supposed donor?
Also, would I be right in thinking that if you put in a different engine (ie new engine number) in a car you need to register this change with DVLA
and therefore they send you a new log book with updated details?
The reason I ask is I'm wondering if that's a way to get an age-related plate when you're engine is not from the same donor as everything else. IE.
first you register the different engine as being in the donor (with DVLA) and then use the new log book when it comes to getting the Locost
registered.
Am I speaking utter gibberish as usual or can this be done? Or are their easier ways...
James
theconrodkid
| posted on 14/4/02 at 06:25 PM |
Sounds reasonable register car in your name with new engine no then wait a bit leaving it on a sorn then do what you gotta do!
Glad you enjoyed your ride but there was no need for the wet kiss.
bob
| posted on 14/4/02 at 06:26 PM |
quote: When you get the car SVA'd and then registered does the SVA engineer check the engine number against the log book of the supposed donor?
Yep,you just send the log book to Swansea and they change the engine number.
Jon Ison
| posted on 14/4/02 at 06:33 PM |
i had a rite time with the dvla, because the engine is only 900cc they thought i was pulling a fast one for cheap tax, (took a 1600cc out)i had to get
an report from my local MOT station before they would change the number and cc in log book,
