7 in a fancy suit
posted on 12/2/06 at 04:10 PM |
Brake pads...for stopping, not wear
I'm will be preparing the Westfield for sprints and hillclimbs within the next few weeks. At my first outing in it in october, I felt as if I
had single leading shoe drums, not vented 4 pots. It has been suggested that the pads may have been very 'hard' for good wear and heat
resistance on longer events, but I need brakes that work instantly from cold. The average hill or sprint only last 60-90 seconds so they will never
get overheated. The car has had an extra fuel tank fitted and makes me think that it may have been tweeked for endurance type stuff.
Anybody know anything about pads that work instantly from cold. I was even thinking along the lines of ordinary road pads?
Colin.
A man gets lonely in the desert.......and bored
NS Dev
posted on 12/2/06 at 04:45 PM |
A lot use std (good quality) road pads for short events like this.
Personally I would opt for Mintex 1144 compound pads.
These work from stone cold, but won't fade when hot.
I have used them successfully on road rally cars a few times and they are great, even as a substitute pad for a standard but "enthusiastically
driven" road car.
JB
posted on 12/2/06 at 05:09 PM |
Brake Pads
Another vote for M1144. I use these for sprints and hillclimbs and they work from cold, but I do find they work better when warm, so I ride the brake
while driving to the start to get a little heat into them
The comparable Ferodo pad is also meant to be very good.
I would tend to only use manufacturers that are seen at the top end of motorsports........
John
Kissy
EBC Green Stuff Pads - work from cold, nice progressive feel and just go on gripping, will be ideal for a car the weight of a seven (they don't
last long on a saloon, couple of thousand miles maximum) - reasonable cost and readily available. The Red Stuff pads need a heavier car and
don't work from cold. HTH
7 in a fancy suit
posted on 12/2/06 at 06:58 PM |
Thanks, just the sort of info I was after.
I probably have something like 'Red stuff' or equivalent in at present....which gave me a hairy moment at the hairpin at the end of the
finishing straight, pulling on the steering wheel and half cursin'/half praying between clenched teeth.
Colin.
posted on 12/2/06 at 07:02 PM |
i have a set of mintex too which i got on nats recommendation. Cant really comment on them as i havent got much to compare them to, but they certainly
stop well.
givemethebighammer
posted on 12/2/06 at 07:28 PM |
More Mintex M1144 here too:
Never let me down on the track or the road yet.
JB
posted on 12/2/06 at 08:01 PM |
I am not a fan of EBC pads after having some in my mountan bike calipers and the pad coming off the backing.
John
NS Dev
posted on 12/2/06 at 08:52 PM |
I'm not a fan of them either after having them break up in the road rally car, and having had the green ones fade under conditions where the
Mintex performed perfectly.
only prob is I don't seem to be able to find mintex pads to fit my raceleda 4 pot calipers!! (same as outlaw/cat motorsport ones)
simon hewitt
posted on 13/2/06 at 08:43 PM |
Brake Pads
Have done 3 trackdays with EBC Red Stuff Ceramics in my MK Indyblade. Awesome stopping power, warm up fast, no fade. I would recommend them.
