locoboy
| posted on 16/5/07 at 07:36 PM |
Drainage work
I need to do the following and would like advice on what items to buy.
I have my own ideas but would like others opinions.
I need to -
Terminate pipe A (Bath water/ sink water/ washing machine) Toward the bottom of the picture and join it into pipe B (Foul Waste)
Place a rainwater gully at point C which will also flow into pipe B (Or more easily join my gully into the new pipe that will run from A to B
Pipe A is above pipe B when viewed from the side.
  drain 1
[Edited on 16/5/07 by locoboy]
Locoboy
PeterW
| posted on 16/5/07 at 07:42 PM |
If its all vitreous clay pipe, then its 3 Hepsleeve couplings, an 87deg bend, 87deg tee, and a length of uPVC pipe.
This assume the normal rule that you can't connect a storm water gulley into a foul drain (which is usually the case) and it would need to go to
a soakaway or storm drain.
If you are allowed, I'd stick a mini inspection chamber in the bottom pipe, then branch everything into that
Pete
locoboy
| posted on 16/5/07 at 07:46 PM |
A mini inspection chamber?
The hole is about 5 feet deep, wouldnt a mini inspection chamber just be covered over with soil and become a mini chamber with no chance to do any
inspecting via it lol?
EDIT
I have no seperate storm drain connection neither does my section of highway, i have had extensive ultrasound tracking and video inspection of the
local drainage done and all i can do is hoof the domestic waste water into the main sewer connection.
what exactly is a hepsleeve coupling?
and how do you suggest i block off drain A?
Locoboy
joneh
| posted on 16/5/07 at 08:08 PM |
You aren't allowed to run surface water into a waste pipe legaly. You need a soak away. Although I won't tell if you don't.
Edit - I really should read other peoples answers before posting.....
[Edited on 16/5/07 by joneh]
