Author: Subject: OT - energy saving lightbulbs
ned
posted on 3/7/07 at 01:31 PM Reply With Quote
I have been using these for a while and think every light except two at home is fitted with one.
I have been thinking of fitting one to my outside light, but have had mixed info as to whether you should or not.
The most recent ones I looked at in tesco's said not to be used with photo cells, which from the picture indicated to me solar panels and they say they can't be used on a timer?
My outside light is a bog standard lantern style jobbie with a PIR movement sensor thingy and stays on for a couple of mins at a time. I know that doesn't sound a lot but if I'm watching telly it does seem to trigger quite a lot and obviously will do all night when a person or car goes down the road. Unless I turn it off I don't really have any control over it, being sensor driven so using 80% less electricity seems a good idea to me.
so what's the score, can I or can't I? and if not, why not?
I have tried googling a bit but I just get loads of energy efficiency rubbish come up so presumably searching on the wrong keywords or terms or summat.
cheers,
Ned.
[Edited on 3/7/07 by ned]
beware, I've got yellow skin
nitram38
posted on 3/7/07 at 02:05 PM Reply With Quote
Ned for that type of light stick to your normal bulb. Low energy flourescent type lamps don't last long if they are switched on and off, plus they don't get up to full brightness straight away.
I know that new led designs are coming out but brightness can be an issue.
Not worth messing about with in terms of energy saved, especially if you have to keep replacing the lamps.
By the way, I am an Electrician.
[Edited on 3/7/2007 by nitram38]
Personally for an outside light I use a low wattage light activated jobby. Comes on at dusk until whenever I switch it off. Means the door is always lit so I can find the lock.... Cheap to run too....
owelly
posted on 3/7/07 at 02:52 PM Reply With Quote
rather bizzarrely, when I fitted these things to my house, they were left on 24/7! They took such a long time to get to full light, it was better to leave them on all the time. By the time the bathroom light got bright enough to see what you were trying to read, the paperwork was done.
And isn't it ironic that most of these energy saving devices are made in China where 80% of the power generated comes from coal fired powerstations and they are building another 350 in the next 18 months...............
http://www.ppcmag.co.uk
posted on 3/7/07 at 02:59 PM Reply With Quote
Absolutely. And worse still, the cheap chinese compact flourescents rarely last for their rate life. I had to change several in my house after a year or two's use.
Given the amount of energy and raw materials required to make them compared to tungsten lamps, I suspect the advantages of CF lamps in terms of eco-friendliness are marginal.
posted on 3/7/07 at 03:16 PM Reply With Quote
Especially when the claimed light output is often so ridiculous!!
I got a 11w (apparently the same as 60W) fluro for my living room. Popped it in, switched it on...
even after 30 minutes warm up it only gets to the equivalence of I reckon a 40W bulb.... I might try a 16w (75W) next...
posted on 3/7/07 at 03:29 PM Reply With Quote
General Electric make some 'mini eco' ones - the glass bit on the top is quite small when compared to the standard size.
They start quickly and give a decent amount of light - much better than the cheapo ones found in supermarkets etc.
Don't buy them in B&Q however - they are around £5 each there - much cheaper in Wilkinsons, if you've got one nearby.
[Edited on 3/7/07 by David Jenkins]
russbost
posted on 3/7/07 at 05:52 PM Reply With Quote
I've got low energy bulbs in 5 outside lights including one which switches on & off - been in for years, must have saved me a fortune, so why aren't I rich?
westf27
posted on 3/7/07 at 06:44 PM Reply With Quote
Cos you been buying eco friendly bulbs
[Edited on 063131p://Tuesdayoc by westf27]
posted on 3/7/07 at 06:57 PM Reply With Quote
In the few places we use them we tend to use them in luminairs that take more than one bulb - in the bathrooms we mix one tungsten with two low energy bulbs so you get some instant illumination
