Author: Subject: Bleeding Brakes!
posted on 12/8/07 at 07:19 PM Reply With Quote
Bleeding Brakes!
Anyone local want to come round and give me a hand bleeding the brakes off?
All my mates are bikers and laugh at the idea of the car... can't wait to show them!
The wifey and the lad are too inept to understand what to do
big_wasa
posted on 12/8/07 at 07:21 PM Reply With Quote
what you mean they dont understand "up" "down" and so on
scottc
posted on 12/8/07 at 07:22 PM Reply With Quote
Would be happy to offer a hand mate.
EDIT: Get yourself a power bleeder thingy and its a one man job.
[Edited on 12/8/07 by scottc]
posted on 12/8/07 at 07:52 PM Reply With Quote
Thought about the eesy bleed thingy but cans are cheaper
Plus easy to get at the local shop.... unless B&Q have eesy bleed kits???
[Edited on 12/8/07 by coozer]
scottc
posted on 12/8/07 at 08:02 PM Reply With Quote
I've got an easi bleed thing, and I'll be in Durham on Tuesday Night. I could drop it off if you want. Only condition is that I get it back soon. As I'm in the middle of sorting the brakes on the Porka.
EDIT: Actually I'll be at Chester Le St Cricket club.
posted on 12/8/07 at 08:24 PM Reply With Quote
Cheers Scott, I wouldn't minfd borrowing it for a couple of days. I'll u2u my munber.
posted on 13/8/07 at 06:33 AM Reply With Quote
you can make yoourself a one man bleeding thingy. Don't have photos so will attempt to describe it.
You need a piece of thin wall plastic tuing that fits over the bleed nipple. Then take 50 mm brake pipe, solder up one end and drill a 1 mm hole in the side. I
If you have pipe flaring tool, put a flare on the open end and this should fit quite tightly into you tube. A short length of the same tube is slipped over the hole in the pipe to act as a one way valve. If the tube is thick walled, it may not flex enough so it would be hard to open the valve resulting in the tube comming off the nipple. (ask me how I found that out -but you can shave the tube wall on the outdie to make it weaker = easier to open).
And hey presto, a locost one man brake beelding tihingy.
