Author: Subject: motive power
posted on 4/11/08 at 08:53 PM Reply With Quote
motive power
need to make a bogie to run 40 miles on fairly level railway track. Only slowly and quietly ideally. Maybe 20mph tops.
I think there is no way to avoid a proper engine, since pedalling isnt ideal. So maybe a rev and go moped sort of thing. A friend suggests a lawn mower engine, but that seems a bit uncivilised.
I would suggest a monkey bike engine but that would be very noisy!
Any suggestions on power source, maybe with transmission ideas too?
Cheers!
owelly
posted on 4/11/08 at 08:55 PM Reply With Quote
What sort of weight are you moving? I have a little go-ped that is quiet enough!
http://www.ppcmag.co.uk
blakep82
posted on 4/11/08 at 08:56 PM Reply With Quote
moped scooter type engine. what's it for?
________________________
IDONTBELEIVEIT
posted on 4/11/08 at 09:28 PM Reply With Quote
i have an outboard motor for sale
reeel quiet
Are We There Yet, Are We There Yet!!!!
posted on 4/11/08 at 09:42 PM Reply With Quote
im not sure what its moving yet, between one and 4 people. Depends how we work it, if it one each or one to share. Its for a bit of fun we have planned, though i think we're a year off completion at best.
owelly
posted on 4/11/08 at 09:46 PM Reply With Quote
http://cgi.ebay.co.uk/ride-on-mower-or-go-kart-project_W0QQitemZ230304151124QQcmdZViewItem?hash=item230304151124&_trksid=p3286.c0.m14&_trkparm s=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
owelly
posted on 4/11/08 at 09:47 PM Reply With Quote
Closer to home??
http://cgi.ebay.co.uk/RIDE-ON-MOWER-CHASSIS-PROJECT_W0QQitemZ330283370907QQcmdZViewItem?hash=item330283370907&_trksid=p3286.c0.m14&_trkparms=6 6%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
blakep82
ah cool, so its like one of these challenge things. like on scrapheap challenge (?) when they made something like this?
maybe a sidecar type thing, motorbike/scooter with no tyres, a wide frame on the side to make a sidecar for the passengers?
tegwin
posted on 4/11/08 at 10:52 PM Reply With Quote
Why not fit a jet engine or two....
Either a Turbojet engine.... Or a turboshaft engine driving the wheels...
You need an old rover gas turbine generator set... use that to drive ur wheels.... would be good for around 10hp :p
www.verticalhorizonsmedia.tv
mediabloke
posted on 4/11/08 at 11:09 PM Reply With Quote
What about a bike engine if you don't need reverse..
More seriously - what about building one of these:
Clicky
Silent and zero-emissions. And not a pedal in sight!
posted on 5/11/08 at 08:20 AM Reply With Quote
How about a train to pull or push it? Proven technology that has been around for over a century, why reinvent the wheel?
Or one of those hand cart things you see in black and white westerns?
Solar panels and electric motor, load of torque at low speed, tis what the trains use.
DarrenW
posted on 5/11/08 at 10:09 AM Reply With Quote
Will it be for a main line? Maybe some flashing lights and air bags would be a good idea.
How quiet does it need to be? Could electrics be the answer.
posted on 5/11/08 at 01:47 PM Reply With Quote
Something like an old Honda C70/C90 will provide a very robust little 4 stroke and 3 speed transmission with centrifugal clutch, and if you can use the original exhaust they are pretty quiet.
posted on 5/11/08 at 05:06 PM Reply With Quote
Perhaps you could build something like this (it's a track supervisor's rail-car from Indian Railways).
It looks suspiciously like assorted bike bits linked to a solid axle with a chain drive.
Doesn't look too hard for a Locost builder to make!
[Edited on 5/11/08 by David Jenkins]
posted on 5/11/08 at 06:52 PM Reply With Quote
thats it david, something like that but a bit longer! We're off exploring
If it ever happens i'll post a vid as it will be a fair old mission
Liking the honda idea, sounds perfect. Cheers!
posted on 5/11/08 at 06:56 PM Reply With Quote
Don't forget that you won't need a diff - the wheel profile takes care of that problem.
blakep82
posted on 5/11/08 at 06:58 PM Reply With Quote
40 miles is quite a long way!
is it a disused rail line or something?
Rod Ends
posted on 5/11/08 at 07:03 PM Reply With Quote
plenty of ideas
