Evening,
Am after 4 pieces of 25mm diameter alloy bar 20mm long with 10mm hole in the center, could also be made in steel. Can anyone oblige?
Alan
As it's a spacer could you weld a penny washer over each end of some 1" tube?
Are you sorted? Firing up the lathe this morning so able to help....subject to having some 25mm bar...I think I do.
Now you tell me...opened a bottle of wine! Operating a cnc lathe whilst pissed....tried that....not good
I can certainly do these for next weekend if that is quick enough.
I have 25mm 7075T6 (aircraft grade alley - hard as nails), EN8 or plain crappo mild steel
Are the dimensions critical? I can easily drill 10mm and part off to your dimensions to +- 0.1mm is that ok?
send u2u with address i will pop them in the post.
In the post
In the post
Welcome!
