I was checking thru some pdf creation videos, and encountered this U-tube clip :-
https://www.youtube.com/watch?v=p1hXvETzG0M
Anyone ever heard of this "MiHelic"? Looked interesting, sounded pretty good.
Wrong!!
But I suppose its one way of getting a Harley round corners
i like it
Originally posted by dinosaurjuice
i like it![]()
i like it![]()
i like it![]()
then you should like this 4x more![]()
Just NO.
I guess the increased number of wheels (over the bike) puts the engine into something probably more suited to it.
Ultimate application for the power unit would be a MF35 or other small chassis.
Something different is always good to see but I suspect this would be a lot of noise with little go. Harley engines are archaic lumps but at least
some character shines through in a bike or even possibly a 3 wheeler.
In a car like this its difficult to see the appeal (unless your partially deaf)
It reminds my of years long gone when in the search for performance we fitted an open exhaust to 850cc mini.
The traffic lights changed to green, the engine roared, slip the clutch and red line it in first, up through the gears, once ,twice, into fourth, the
sound was awesome the g force less so, a glance at the speedo and we touched 40
[Edited on 6/1/17 by SCAR]
There is also this one - bit more of an exo style to it -
http://www.twintechcars.com/
I think I'd stick with the current Morgan 3-wheeler, with it's much-modified Harley engine - a much more suitable vehicle.
Well I for one like it, but then again I've got a soft spot for harleys as ive owned and tuned a few in my time, as others have said they are an
ancient design blah blah blah, but what the engines do make is bundles of torque at low rpm, it's quite easy to build a 125/125 bhp/torque
engine, nothing great but enough to get you along ok in a lightweight 7 type car.
As for the handling, harleys werent always sleds, back in the times of the translantic races of the 70's a certain cal raybourn came over from
the states on his " crappy old pushrod harley" and prompty won 3 out of 6 races, the pi$$ taking soon stopped.
Shooter
