Water Pump Zetec
prelude1980 - 9/11/08 at 04:50 PM
Anyone know if you can cut the impeller off a blacktop water pump, so that the pulley will still work.
I'm fitting an electric water pump an need to remove the mechanical pump but still need the pulley in place
coozer - 9/11/08 at 06:07 PM
I think the impeller will come off as there is a one that can be put in so goes round the same as the crank pulley.
May just be pressed on.
