Hi,
just found this webiste:
Oil filter Variations
and it shows different variants for the shorter oil filters that have been used for the zetec as per this post
link
Can anyone confirm if these are the same size in dimensions, as I am having problems fitting a filter due to the steering column shaft.
Ian
I considerd a very short filter from a Renault 5 but ended up with a remote filter head, not wanting to comprimise Henry's proposed filter size.
Not the cheapest option but gives me piece of mind.
OK, the link to the post on here is pretty old and i have managed to find other options.
The FRAM 2874 is short but i manged to find FRAM 4546 even shorter and used that for the last couple of years.
At my last oil change i fitted a PUROLATOR L17825 oil filter which is a couple or 3 mm shorter (every bit helps) these are listed as renault 5 turbo
parts among others in the renault range of early 80's cars.
Some have said the threads are not the exact fit but i have had no issues with these filters in the last 3 years.
Hope this helps
Here's my standard post on this issue from 2 years ago:
Originally posted by SeaBass
I had a good look around for a decent filter for my Zetec. All the usual suspects were just that - suspect eg using a Renault 5 filter which is M20 on a 3/4" ford oil filter thread - no thanks. I ended up using a short but fat filter from a Ford XR4x4 V6 / Cossie 2WD. Ford oil filter code EFL 298.
Looks like this:
I found the MANN filter catalogue online to be very useful. You can supply the dimensions you want to use and it comes back with suggestions.
MANN Filter Selector Here!
Hope this has helped...
Yup, I tried the renault 5 filter, would have been superb on the B but was not happy with that thread mix, it screws on but is not right.
I've got a brand new R5 turbo filter if anyone wants it for the cost of posting, couple of quid I'd guess.
Halfords HOF266 fits perfectly on mine. Dunno if the thread is different, but it screws on just as well as the proper Ford one as far as I can
tell.
Stu
I think the thread problem is that the Zetec engine has a 3/4"UNF thread (19.05mm dia) and some Renault filters have this thread, but others have
an M20 thread with a similar pitch to the UNF one.
Until I investigated I found the M20 threaded filter would screw on easily and grip on one oil pump, but on a spare pump it would not gripwhen
tightened.
Mal
Just take it off and stick a bolt in the hole!
I used this sort - Fiat Cinquecento / Siecento one.
Ebay item number......
360000664643
Same length as the short remote head so there is no size benefit in going for a remote unit.
Chris
I just added another ujay to the steering shaft to alter the angle, then fitted a bush and a bracket to carry the modified shaft passed SVA covered 5000 miles no problem. Standard zetec filter used modification cos £15.00
Thanks folks for all the replies.
I went to local motor factors and they had the one off the list, COOPERS Z107.
Fits perfectly and is roughly half the size of the Halfrauds hof200.
Only £5 too, bargain
