Polo Rad Blanking
Pdlewis - 20/11/08 at 10:13 PM
Anyone know what can be used / where i can get somthing to blank the thermostat take off on a MK1 polo rad?
Dangle_kt - 20/11/08 at 10:19 PM
You could always buy a thermostat switch, I think they are about £3 on ebay.
mad-butcher - 20/11/08 at 10:20 PM
If you mean the little pipe at the top, short length of pipe with a bolt stuffed in it, or you could tap it and put a bolt in
jambo - 20/11/08 at 10:45 PM
got the switch from mnr
adithorp - 20/11/08 at 10:45 PM
If you mean the rad fan switch hole then u2u me your address and I'll stick a plug in the post.
adrian
David Jenkins - 21/11/08 at 08:44 AM
I bought a thermo switch and wired it in parallel with the one on the thermostat housing - the fan comes on if either switch operates.
smart51 - 21/11/08 at 09:30 AM
I tapped the little pipe at the top and put an M5 bolt in it. Handy for bleeding the radiator when doing a coolant change.
Pdlewis - 21/11/08 at 09:47 AM
Cheers guys got a fan switch blank sorted and seems like tapping the outlet is an excelent idea i was wondering how to get air out the system
TimC - 21/11/08 at 02:05 PM
Is this definetely not needed? I have it tee'd into the hose that runs from the thermostat itself to the header. However, it's a bit untidy and has sprung a leek, plus it makes nose-cone removal a bit tough. If I can get shot of it, I will.
TimC - 23/11/08 at 08:22 PM
Anyone?
