4age 20V: which coil/igniter ?
RichB - 2/12/08 at 08:59 PM
Hi
Does anyone know if a 16v 4age coil & igniter can be used on a 20v? Or a silvertop 20v on a blacktop 20v?
Rich
tootall - 2/12/08 at 10:47 PM
dont think u can use a 16v coil igniter on a 20v but think u can change between silver top black top as they are a very similar wiring loom . i wired in and fitted a black top to a mk1 mr2 last year for a customer of mine lovely engine carnt fault it
bimbleuk - 3/12/08 at 07:59 AM
I'm not using a Toyota coil pack. I think its a Vauxhall item supplied by RAW with all their kits. Anyway I've used it on a 16V engine, the Silvertop 20V and Blacktop 20V but its controlled via an OMEX ECU referenced to a crank timing disc. So theoretically what works on a 16V should work on the 20V as the spark requirements are similar.
Have a look on the www.club4ag.com technical section or post a question on the forum if you don't gt a definite answer on here.
[Edited on 3-12-08 by bimbleuk]
tul214 - 3/12/08 at 11:36 AM
The coil pack I received from RAW was of Peugeot/Citroen heritage.
Looks like a few different options?
Mark
RichB - 3/12/08 at 12:52 PM
Ok thanks guys. 'cos I'm going to be using the standard ecu (etc) i'll look on club4age. I guess Raw's OMEX unit is a bit more flexible than toyota's!
Rich
