how close are they? i need to start on my exhaust manifold, but i'm wondering if i could get a manifold form a race truck, cut the flange off,
and weld on a ecotec flange i got from short track.
would cost more, but a lot less hassle i'd say
edit:
or even how close the ecotec might me to Zetec and zetec E, all 2 litre
[Edited on 14/1/09 by blakep82]
you have u2u, XE and Ecotec are defnitely the same (as is the vauxhall 8 valve)
not sure on zetec but as the 2.0 is 86 bore 86 stroke same as the vx engines then prob the same as I doubt they were much more inventive with the cast
iron block material
Hi mate, if you need the headers for a redtop/ecotec then ive got a complete manifold i wont be using.
cheers craig
have you got any photos?
mine is to be used on the pickup truck remember, so the exhaust needs to go down the transmission tunnel. a one for a 7 type car isn't likely to
fit it think
Originally posted by blakep82
cheers craighave you got any photos?
mine is to be used on the pickup truck remember, so the exhaust needs to go down the transmission tunnel. a one for a 7 type car isn't likely to fit it think
cool
might be a good start, depending on how its made.
mine really ought to be a 4-2-1 system, and has got about a 12" space down the side of the engine for all this to happen before it heads down the
tunnel
this isn't the greatest photo, but you see what i'm contending with lol
