HELP!
ive shortened my sump and pickup pipe on my ZX12R engine and replaced it all. Filled up with oil and no i get no oil pressure and the oil light is
constantly on. ive let it idle for a few minutes and i still get nothing so im looking for solutions before i damage it (or have i already done this).
The sump and pickup pipe were off for about a week and the engine left to drain into a bowl so its very dry in the oil ways.
Is there anyway to prime it or has the sump got to come off again?
Please help this is the lasdt thing to get me back on the road and im itdching to go out the w/e.
I only cut 15m off the sump and pickup pipe.
~Cheers~
How are you assessing the amount of oil requierd? If you do a sump-chop you can't rely on the eye-glass or the dipstick any more because the amount of oil in the sump will obviously be different for the same level reading....
Did you reconnect the oil pressure switch?
you can try getting a mate to slacken the oil filter whilst turning engine over with no plugs in as sometimes they can airlock.If this is case you
will hear a hiss of air followed by driblle of oil. Then tighten filter and check for pressure
Do not let it run until you haveoil pressure as the shells will pick up real quick
ok first off i have filled it up to max on the eye glass, i also have welded more onto the front of the sump increasing the oil capacity.
Oil pressure switch is wired ok, mechanical oil pressure gauge is also fine (i losened this connection and oil dribbled out).
i started the engine, let it idle for 10 seconds, saw no oil pressure, stupidly blipped the throttle and let idle for another 10 seconds. switched
off. i then restarted and let idle for about 15 seconds.
i thought maybe i knocked one of the oil pipes off in the sump when wiggling it over its location dowles but i think its an air lock. When originaly
taking the sump off and letting it drip over night when i pulled off the oil pickup lots more oil then came out of that pipe so it must hold oil in
there to maybe keep the pump primed?
I hadnt fitted a new oil filter (lazy and didnt get one) and ive just now tried to take it off and cant, its wedged on solid!
My oil filter wrench (chain type) has split it and now im wandering how to get it off?
Googling the oil pressure problem does seem to point to 'burping' the filter just as you say Andy B. I will try this with a new filter in
the morning without the engine firing and just letting it spin on the starter.
Im more worried about the damage i may have caused blipping the throttle and letting it idle with no oil pressure AND no standing oil around the
various bits in the engine as its sat stil for 6 weeks.
What would be the main damaged parts that 'go' with no oil in the system?
[Edited on 20/2/09 by Moorron]
When you chopped the pick-up did you cut a few notches in it for oil to get in? ie. it's not sat flat on the bottom of the sump?
If you want to check for peace of mind - drain the oil into a clean cotainer and slowly decant it into another. You are looking for small silver/gold
flecks of metal about the size of a tea leaf. If you find this it is small pieces of big end or main bearing shell picked up by the unlubricated
crank. If that is the case do not run it again until you have stripped down the bottom end and checked/ replaced the shells or it will go pop.
If you struggle with the filter Honda do a proper pressed steel socket with a 17mm nut for a spanner - they are not expensive and I will get a part
number for you asap
regards
yeh i cut the pickup so it replicated the 'gap' the original did so im sure that ok.
cheers Andy. The oil filter is mangled now so im going to get the removal tool that are like a strap and hope this wont slip it more. i think i know
what you mean with the honda too, but even if i had one i dont think it would fit now.
Cheers tho.
im going to prime the new filter, 'burp' it with only the starter cranking and se if i get any pressure. if i do im going to see if it runs
ok upto temp without any nasty noises.
not happy, but reading on the net shows others with the same problem who didnt suffer any damage after letting it 'run' for 5 odd minutes!
fingers crossed.
I had the same problem after I fitted a dry sump system. It turned out to be an air lock within the hose to the remote mounted oil pressure switch. I'd remove the plugs and oil pressure switch. Then turn it over on the starter to see if you get oil out of it.
Originally posted by Moorron
I hadnt fitted a new oil filter (lazy and didnt get one) and ive just now tried to take it off and cant, its wedged on solid!![]()
When you get the oil filter off, and just before you install the new one (which will be filled with oil before you install it) take and oil can and
squirt some oil into the hole coming from the pump, may help to prime it.
With V8 Chevys a shaft is put down the distributor hole and twisted with a drill to prime the oil system.
if it helps - Halfords do a pair of oil filter removal pliers, like expanded water pump pliers with teeth.... about £8 and works a treat. Previously had to use a 2ft wrench...
cheers. Today i went to get a filter from the local bike shop and they didnt stock them! anyway i went to halfords and they had one in
i also got
one of the filter removers that is like a metal strap with a clamp on the end. Worked a treat too. filled new filter with oil, spilt it all over me
putting it on and then turned the starter over and just about reaching the filter i wound it off untill oil sprayed out and then done it up to see
bubbles and then up further and watched the oil pressure rise! Great news. ive been out in it for a quick blast and all seems fine.
Cheers lads
