Im looking at SU carbs on fleabay but have noticed there are different types.
Im planning on modifying my current (EFI) manifold to use on my 3.6 and wanted to make sure that getting twin SU's off a 4.2 Series 3 XJ would be
up to the task
Your fuel economy is going to be bad enough... don't you want EFI to maximise it?
James
what's the engine, make/model./year - I have SU books so can take a look and tell you what was fitted at factory.
from memory the 6 cyl jags had twin 2 inch SUs, I think the E-type had triple 2 inch.
oh, just remembered, go over to burlen.co.uk - the peeps who took over SU - they have online application page where you can enter ^^^^ info. - saves
me remembering and looking in my books - it may be more up to date too.
[Edited on 5/3/09 by 02GF74]
I don't think it will work
(1) Jag SU carbs have no cold start facility, so you would need to fit the electrically operated SU cold start enrichment carb and its thermal switch.
(2) Your manifold won't be water heated so the above won't work properly.
Megasquirt or micro squirt it.
[Edited on 5/3/09 by britishtrident]
The engine is a 3.6 AJ6
I want to have it on carbs as it looks so much nice imo.
Fuel economy??? Who cares, the car wont be used much anyway (plus i have a 50l tank
). Anyway, i want to encourage global warming so i have nice
weather to drive in
ETA - i thought about megasquirt for it (i read that some bloke up north megasquirted a 4.2 Etype and is getting 48mpg combined
) but it looks quite
expensive, confusing and teh horror stories i have read about locostbuilders trying and failing to set it up.
[Edited on 5-3-09 by speedyxjs]
Sorting out a Mega Squirt is nothing compared to trying to find the most suitable SU carb needles ---
You could always use the SUs as throttle bodys and discretely fit a set of injectors.
It is much easier to set up injection with an AFR meter and PC than having to guess at different needles and springs etc.
Paul.
Fuel economy??? Who cares, the car wont be used much anyway (plus i have a 50l tank). Anyway, i want to encourage global warming so i have nice weather to drive in
ETA - i thought about megasquirt for it (i read that some bloke up north megasquirted a 4.2 Etype and is getting 48mpg combined) but it looks quite expensive, confusing and teh horror stories i have read about locostbuilders trying and failing to set it up.
What about bike carbs? Same principle as SU's but easier to setup and better mpg...
Ok, what bike carbs are best?
