Whats the difference between the cosworth yb crank and a pinto crank?
Pinto has 6 bolt fixing for the flywheel
Cosworth has 9 bolts.
Both cranks are bullet proof if prepared properly but the 6 bolt crank needs a locating dowl or two if you intend to race it or go to 7500 to 8000 for
long periods of time.
All the dimensions are the same
[Edited on 5/4/09 by snapper]
cosworth one is steel and has more flywheel bolts.
If you dowel the flywheel to a pinto one though then I'd like to see one break!
There's nothing much wrong with a std pinto crank other than the flywheel mount.
if i remember rightly i have 2 dowls in my pinto crank and my flywheel is only 3.68 kgs
then you'll be safe to a lot of revs as long as everything else is balanced.
7500 is certainly safe
and aswell as the above the cossie one has a 8mm longer nose (so more space for pulleys) and 2 short keyways instead of 1 long one
Alex, if your thinking about building a cossie from a pinto - don't do it, its cheaper to buy a whole cossie and rebuild it (4x4 one for
preferance)
I found out the hard way
[Edited on 5/4/09 by mcerd1]
