4speed - 5 Speed
locoboy - 20/2/04 at 12:58 PM
Hi all,
I currently run a 4 speed box on a pinto in my F27, I want to go "modern" and install a 5 speed.
As my car is already built etc there are a few critical dimensions i need to check out.
A) Is the overall length the same, from Bellhousing/engine face to end of gear box rail?
B) is the distance from bellhousing/Engine Face to gear lever insetrion the the same?
C) is the bell housing the same diameter on the 5 speed?
I basically want to know if its a direct replacement and wont mean any re cutting of holed in tranny tunnel for gear stick and shortening of propshaft.
timf - 20/2/04 at 01:24 PM
the 5 speed is longer
the gear lever is further back
belhousing is the same
200mph - 20/2/04 at 01:51 PM
and I believe the 4spd prop shaft would need shortening to compensate.
mark
locoboy - 20/2/04 at 02:03 PM
Shit
sebastiaan - 20/2/04 at 03:45 PM
If you are running a type 3 box at the moment, a type 9 will fit straight in. (see burton power website for gearbox pics)
Overall length is the same, gearstick position is the same, only differences are:
input shaft (is 20 splines on type 3, 23 on type 9)
output shaft (type 9 is a bigger diameter)
gearbox mounting (type 9 is further back)
the type 3 box was fitted to early sierra's
200mph - 21/2/04 at 12:03 AM
apologies, I didnt see the pinto bit of your post. They should be the same, just an extra cog with the 5sp box
Mark
