Having now blown a fistful of fuses with my rad fan (now discovered it pulls 100amps when it start up and runs at about 25 to 30 amps) I need to
source a new fan el pronto. SVA on the 16th April
Does anyone use the budget fan sold by SVC at £30? If so any good or can anyone recomend a cheaper new alternative that works?
I took mine from a rover metro in the scrappy. Pulls 20amps on startup and draws a steady 10amps when running.
Cost the grand total of a tenner and fits really easy too.
Just disconnect it for SVA, its not tested. Or, is it required to stop the motor going EEEEEKK?
wire it up to a relay would be quickest and cheapest i think
Another vote for the Metro unit, I bought mine new from Newark for £10.
Chris
100A?!
youll probably find that the fan is designed to be used with a 'soft start' controller. commonly fitted to big machinery to stop jerks
etc.
the fan on my donor had a controller, there fairly common on bigger cars.
too complex and unnecessary for a kitcar - just fit a smaller/simpler fan.
I'd drawn the conclusion it is meant to be used with a controller.
Blooming powerful though. I have to keep the handbrake on or the car moves
just out of interest, what fan is this? (diameter?)
number oif solutions
a) fit 100 A or bigger fuse
b) fit soft start module
c) fit fan(s) that draw less current
re: c, if you need a massive fan, then fit 2 smaller fans assuming you can get coverage over radiator (rectangular vs square) and then fit a 2 stage
temp switch - these wold stagger the turning on of the fans so that you won't get start up current drawn by both at same time.
The fan was bought at a Stoneleigh show a couple of years ago. so not a lot known about it.
I've gone for the Metro solution now. A brand new one for £10, which seems good value to me, is now winging it's way to me.
