Does Zetec 1.25 fit straight onto type 9?
Surrey Dave - 16/4/09 at 10:32 AM
Also could the standard injection be easily used?
iank - 16/4/09 at 10:38 AM
No, it's a Zetec SE which need a different bellhousing.
[Edited on 16/4/09 by iank]
Surrey Dave - 16/4/09 at 10:42 AM
Does it have an aluminium block?
Madinventions - 16/4/09 at 12:35 PM
My 1.25 Zetec is from a 96P Fiesta, and it is an aluminium block, and you can easily re-use the injection system and ecu. I did exactly this on my Mojo.
http://www.madinventions.co.uk/mojo
Best regards,
Ed.
mattf - 16/4/09 at 03:05 PM
There are bellhousings available from Shawspeed, Burton Power, Caterham and Westfield to fit the 1.6 version of the Zetec SE engine to a type 9. I expect that they'll fit the 1.25 (and 1.4) Zetec SE as well.
iank - 16/4/09 at 04:12 PM
Yes it's all aluminium (designed by yamaha iirc) Also called the Sigma if you're googling.
http://en.wikipedia.org/wiki/Ford_Sigma_engine
Also need to take into account that inlet and exhaust are on the opposite side to regular zetec's.
Here's the dimensions and info from Ford.
http://www.fordpowerproducts.com/FordPowerProducts/pdf/ZSG_Range_Leaflet_4_2003.pdf
Surrey Dave - 16/4/09 at 04:31 PM
