EFI to carbs: what do i need to keep?
Miks15 - 16/4/09 at 04:35 PM
As title really. Im now going to be using GSXR600 carbs on my 1.6 BMW engine. What do i need to keep from the standard setup to get it working?
Does it need any of the sensors etc?
How will the ignition setup differ?
Thank
Mikkel
blakep82 - 16/4/09 at 04:43 PM
are you thinking of using megajolt for ignition?
on my engine, i've stripped everything off, only keeping water temp and oil pressure sensors.
i'm using megajolt for ignition, and i never really understood the BMW ignition system, so i don't know how it works, or if you can use it, but megajolt only needs tps, and crank position
Miks15 - 16/4/09 at 05:02 PM
whats megajolt?
I wasnt sure if my ignition system was being run by the ECU or if it was independant of it.
blakep82 - 16/4/09 at 05:21 PM
megajolt is an ignition system. uses all ford bits.
but wait, does your engine have a distributor on the front? you might be in luck
Miks15 - 16/4/09 at 05:52 PM
yes it has a distributor on the front
as you can see here...
god i hate looking at these pics with my dirty enigne
yellow melos - 16/4/09 at 06:31 PM
is that one of those persective shots or is that engine gonna stick out the top of the bonnet by about 2 feet
Miks15 - 16/4/09 at 06:43 PM
Its been dropped about 2-3 inches inches since that photo. So it should be ok
mark chandler - 16/4/09 at 07:11 PM
That looks like a fixed distributor so the EFI unit will be applying advance etc, common in lots of late 80's cars. You will need to supplement with some electronic wizardry like megajolt.
omega0684 - 16/4/09 at 07:33 PM
is the engine supposed to be at a slanted angle ?
Miks15 - 17/4/09 at 09:28 AM
Bollucks thats where ive been going wrong
but yeh thats how it came out of the car.
Can anyone tell me more about megajolt then?
