measurement of 1600 crossflow DCOE manifold
02GF74 - 27/4/09 at 10:28 AM
okey dokes, the twin sidedraught carb inlet manifold for Ford Crossflow engine comes in at least 4 flavours:
long and short, one each for 1300 and 1600 engines. The 1300 block is about 30 mm shorter to the manifold for it I believe are angled up more in order to clear the distributor.
Does anyone have the long 1600 inlet manifold?
If so, could you measure the difference in height between centre of inlet port and centre of carb bore?
and is the face for the carbs veertical or angled?
