Can anyone help i need torque settings for head bolts and cam caps thanks.
I have the below from a haynes manual for a silver top, would imagine they are going to be the same possibly
Cylinder head bolts
Stage 1 - 25 Nm
Stage 2 - 45 Nm
Stage 3 - Angle tighten a further 150 degrees
Camshaft bearing cap bolts
Stage 1 - 10 Nm
Stage 2 - 19 Nm
[Edited on 14/5/09 by prelude1980]
From autodata. ST170 engine
Head bolts
Stage 1 20nm
Stage 2 40nm
Stage 3 90'
Sequence
belt end 10 4 2 6 8 flywheel end.
---------------7 5 1 3 9
Cam caps 15nm
[Edited on 14/5/09 by Danozeman]
Many thanks for your help.
Cylinder head bolts
Stage 1 - 25 Nm
Stage 2 - 45 Nm
Stage 1 - 10 Nm
Stage 2 - 19 Nm
Head bolts
Stage 1 20nm
Stage 2 40nm
Stage 3 90'
Cam caps 15nm
