im turboing my pinto,im useing carbs,for the mo,iv got lumition optroic,some on said that i will need to change the spark cuve,but didnt tell me how
or what it is???
i can only think its to do with how long it sparks for??
dont know
By spark curve , what they mean is ignition advance - which , when drawn as a graph , is a sort of curve .
Problem with a distrubuter is - with boost , you (I think) will have to retard the timing and I dont think a dizzy can be made to do that .
Megajolt/squirt will sort that
Megajolt/squirt will sort that![]()
Megajolt/squirt will give you so much more control with other inputs available such as water temp control.
Its cheaper than modding a clockwork dizzy and gives you 3d mapping
