Where can I buy a set of adjustable needles for my ZX9R bike carbs?
Mine came with them in but I suspect they where from a Dynojet kit, thats based on the air bleed jet beign blocked off.
Mine came with the dynojet kit. You're very unlikely to buy them on their own. I believe you can just place washers on the end though.
i have some washers,il tell you what though,i thort i was running a bit lean,so i added 3washers on each neadle,about 3mm,far to rich,ended up useing
1 in each 1mm of washer,
what motor is it?
if its a pinto what size are the jets drilled out to?
[Edited on 27/5/09 by jpindy3]
also if you have the std kinhin neadles there is about 10mm of ajustment by useing washers and i think that that is plenty,
I have a 2 lt Pinto. The carbs were bought from Bogg Bros so I am not sure what size the jets are. I just told them what my set up was
I am going on a rolling road in the next few weeks and wanted to be prepared
