hi there,what hand is the crank bolt thread,the bolt that holds the pulley,is it left or right
im trying to undo it
oh sorry its on a pinto
[Edited on 14/6/09 by jpindy3]
Originally posted by jpindy3
hi there,what hand is the crank bolt thread,the bolt that holds the pulley,is it left or right![]()
I would expect it to be right hand i.e. normal thread - never heard of it being LH and I am sure it would have been mentioned by now.
Starter motor method is quire brutal - I would use, and have done - a long breaker bar, push on that than give it a whack with a mallet or try a windy
gun.
Put car in loow gear, hand brake on and a block of wood before the front wheels.
You should be able to get it off - vauxhahll 16 v engines are nototoriously diffficult to undo.
