idle speed when cold
richwill - 19/6/09 at 09:31 AM
My pinto will not rev steadily when cold. It hunts up and down until its warmed up for 5 minutes or so. What is the cause.
(Standard pinto efi injection set up)
cd.thomson - 19/6/09 at 09:34 AM
my 205 does that too and pretty much did it from the factory, sure it isnt just a symptom of an old efi system?
Grimsdale - 19/6/09 at 10:35 AM
it's the idle speed control valve, the cylindrical object on the engine side of the throttle butterfly. Unbolt it and douse it with meths or similar to un-gunk it, lightly lubricate and refit.
I must add one looks like a right cock when at a pedestrian crossing one's engine starts revving, causing those on the crossing to scatter for their lives. I nearly died of embarrasement.
[Edited on 19/6/09 by Grimsdale]
richwill - 19/6/09 at 10:55 AM
Thats the same thing i had happen this morning. I will give it a clean and see what happens.
rusty nuts - 19/6/09 at 11:59 AM
Clean it with carb cleaner
adithorp - 19/6/09 at 12:11 PM
Clean the idle control valve and the throttle butterfly/housing with carb cleaner.
