Drives like turbo is not coming in have changed mass airflow meter, not that what should i be looking at next. Revs right through the rev range but no turbo boost.
wastegate/ boost pipes
Boost pressure sensor? Boost pressure converter (N75 valve)
Check all the vacuum pipes first mate. they often pop off under the air box. The pressure convertor is the valve the front of the engine next to
the cam cover. They are common as are the vacuum pipes perishing. Also the mechanism for the variable vanes in the turbo seize up.
What age is it? MIne was like this when i bought it. The pump timing was way out. even a tooth on the fuel pump will give you trouble.
Its a s reg 1999 with a seperate map sensor
110? Thatl be AFN engine code. Check my suggestions above mate. Same as mine. Does the turbo just not come in or does it come in a drop out
straight away?
ukpassats.co.uk is good for info
[Edited on 23/6/09 by Danozeman]
Had the wastegate stick open on mine a year or so ago. No symptoms apart from no boost. Couldn't even tell there was a problem driving round town.
I had a similar fault, turned out a MAF sensor wire in the loom was broken, put it into limp home mode.
HTH
Neil
I had a similar (if not the same) problem on my 2000 AFN in an Audi A4 1.9 tdi. It turned out to be one of the small diameter hoses (maybe vacuum?) connected to the turbo. It had a hole worn in it due to bad routing.
