Bought a mk1 mr2 for its engine, fitting into a mid mounted mini based kit car.
So, what can I remove from the engine?
Am looking into running MegaJolt so thats the dizzy gone, but what else?
Mini project
Have you seen this?
I have a 4a-ge motor in my Tiger. I am using an Omex ignition, so like you no dizzy and I have just swapped the twin 45 dellortos for a set of cbr600
carbs. Either way you don't need all the inlet/fueling gear on the mr2 engine.
I suppose in a mid engine mini you will be using the gearbox so keep that!
Other stuff like radiator, alternator etc... you could re-use.
