As above?
Cant see anything with any needle rollers in there. Only a solid little thingy at the very rear of the crank?
What do we think?
crank
No spigot bearing in there.
Has the engine been used in a RWD car before?
There's some notes and photos on installing the crank seals on my website. The link is below, then go to the Westfield bottom end rebuild page.
Should fit without dropping the sump but don't re-use the seal. Fit a new one.
go to ford and buy a spigot (about £11) and it pushes in to hole in the end of the crank. Front wheel drive cars don't use them hence you have to fit one to use it in a 7. As for the seal no idea but i would buy a new one not just shove the old one back in.
anyone got anywhere go go buying one please?
Cheers for the advice thus far!!
Oh, and which way does the spigot go, needles front or back??
does it go until it goes no more?
Cheers Tony! Going to give it a bash in a moment!
Any advance on where to get the oil seal from anyone?
Front wheel drive cars don't use them hence you have to fit onequote:
Hmm, of no use to you what so ever but when I dragged my zetec out of a rather banana shaped Focus and took the box off I was surprised/pleased to see a spigot bearing already in there![]()
David Jenkins - 9/7/09 at 11:38 AMMy x-flow came from an automatic car - it didn't have a spigot bearing, but did have a steel cup press-fitted over the end of the crank.
blakep82 - 9/7/09 at 11:43 AMwhy don't FWD cars have a spigot bearing?
adithorp - 9/7/09 at 12:02 PMquote:
Don't bash it too hard. I've seen it done that the outer casing folds over a bit and binds on the needles.
adrian
ps. thats not the spigot that missing, it's the spigot bearing. The spigot shaft is the shaft coming out of the gearbox with splines to engage the clutch plate...just so we're all talking about the same thing.
fatbaldbloke - 9/7/09 at 01:07 PMYou can get them mail order from Burton Power as well.
