question for the stainless welding and exhaust experts
blakep82 - 30/7/09 at 07:59 PM
my new (2nd hand) exhaust is a work of art
but, the manifold is for a vauxhall XE, and i need it to fit my XEV ecotec.
you can see the plates are a little different,
so, the question is, do i have the flange plate swapped over
OR
do i have the original one built up, with some extra bits of stainless welded on, and the holes redrilled?
i guess 907 is the man to ask on this one?
zilspeed - 30/7/09 at 08:04 PM
Adding bits on, it'll never be flat enough to get a proper seal.
Get a new flange onto it.
I'm a monkey of a welder and I could do that.
Incidentally, your manifold looks fair to me.
whitestu - 30/7/09 at 08:17 PM
I used a CVH manifold on my Zetec by welding a Zetec manifold plate on top on the CVH one.
My welding isn't great, and this made it a lot easier to do.
Stu
jpindy3 - 30/7/09 at 08:19 PM
is this to pack it out so it dont hit your box?
if so why dont you use long studs and 2 sets of gaskets and use the other flange as a packing peace.
if not i could weld it for you but im down here
MakeEverything - 30/7/09 at 08:41 PM
Cant you just notch the manifold flange like they did on the old mini? The nut and washer clamped the manifold rather than bolted it down. Locost Version, and quicker too.
jpindy3 - 30/7/09 at 08:54 PM
how dose the flange look incomparison to the exhaust ports?maybe the holes in the flange on the exhaust are to big
blakep82 - 30/7/09 at 09:16 PM
i was looking at it the other day, i don't think it will hit the box, the gearbox isn't bolted in right (which i forgot about) so it will move away from the exhaust by about 1/2" so no need to space anything
its just needing done because its a different cylinder head,
zil i know what you mean about adding bits on and it not being flat enough, joe welded a inlet manifold for me the toher week, and then sort of 'skimmed' it flat, so it should be possible to do on this too i'd have thought?
jamie, i think the ports on the manifold are a little bigger than they need to be, not sure why though, but thats part of why i'm wondering if extending bits on the original one might be a better idea.
mark chandler - 30/7/09 at 09:34 PM
Larger ports on the exhaust manifold is a good thing, a mismatch here is recommended in the ideal world level at the bottom, mismatch at the top of the port.
As you have both plates but it sounds like gearbox spacing may be an issue I would cut the old plate 3/8" around the outside of tubes so you gain a little then weld on to the new plate, not try and cut off flush.
Regards Mark
[Edited on 30/7/09 by mark chandler]
jpindy3 - 30/7/09 at 09:53 PM
cut the flange off and weld the new one on,looking at it more doing this is easyer
blakep82 - 30/7/09 at 10:30 PM
Originally posted by mark chandler
As you have both plates...
ah, good point, i have got the ecotec plate, its in mild steel, 6mm thick i think. might be 8mm. the original is stailness and 10mm thick. i'd prefer to stick with stainless i think.
btw, the gearbox spacing shouldn't be an issue now, so don't be thinking about that!
[Edited on 30/7/09 by blakep82]
907 - 30/7/09 at 10:50 PM
You have email Blake
Paul G
