Got my new digidash from ETB Instruments the other day, and starting to plumb it all in. I've got all the engine sensors on my Zetec bar one;
the oil temperature.
I've got a thread adaptor and was just wondering, as per the recomendations from the instruction wiring diagram, would it work effectively in
place of the sump plug?
I've got 2 UJ's in my steering column, and as such have a small oil filter as it's a touch tight on room, so I think a sandwich plate
is too big. But I was also thinking, do I need an oil cooler due to the shortened sump?
I'm sure I can combine the two somehow - was thinking along the lines of an oil filter relocation kit plumbed into the block, with the oil cooler
on one of the take-offs, and the temp sender screwed into it somewhere?
Thoughts, all? Any pictures of installs comprising of any of the above suggestions would be interesting to see...
pretty much what I have done
remote filter take off on block
plumbed to remote head with a sandwich plate take off for oil temp and pressure then to filter and then back to block via cooler (better to filter hot
oil from what I gather?)
I'm sure I have some pics somewhere??
Will post when I find them
Regards
Rob
Remote filter and take off and sandwich plate not visible in this shot though..
sure I have some closeups showing it
Will keep on looking
Unfortunately the car is engineless and pretty much stripped for a pre winter re-build ...no garage so making hay whilst sun shines :-)
Regards
Rob
