pinto cam belt tension
kj - 27/8/09 at 07:14 AM
How did you set you cam belt tension on a pinto, use any gauge or just half inch of movement as some mention?
Also is it ok not to use the spring as it was not on my old engine.
cheers
britishtrident - 27/8/09 at 07:17 AM
Not a half inch of belt movement --- the standard test is if you can give it a half twist of belt movement on the longest run.
[Edited on 27/8/09 by britishtrident]
adithorp - 27/8/09 at 07:37 AM
Get hold of the belt with finger and thumb on it edges, on the longest run and trist it. Should get 90' turn (without all the force you can muster).
adrian
ashg - 27/8/09 at 07:38 AM
As bt said.
you should be able to do half a twist on the longest part of the belt.
kj - 27/8/09 at 08:05 AM
Thanks, sorted.
Surrey Dave - 27/8/09 at 08:32 AM
Just to clarify , you should be able to turn the belt 1/4 of a twist = 90 degrees
kj - 27/8/09 at 12:26 PM
Thanks for that just wanted to check
