Why replace coolant?
smart51 - 2/9/09 at 01:51 PM
Why does engine coolant need to be replaced every couple of years? does it go off? I always do it but was talking with someone who flushes the system out with water before draining again and filling with coolant. Is there some contaminant in the old coolant that should be cleaned out before refilling?
rost - 2/9/09 at 01:57 PM
iirc, it's just that the anti-corrosive agents stop working after some time. Just draining/replacing should do the trick.
Mr Whippy - 2/9/09 at 01:58 PM
Usually its dirty from scum or limescale. I’ve had to back flush radiators quite a few times to clear garbage from inside them, often the water that comes out is totally filthy
Bluemoon - 2/9/09 at 02:10 PM
Removal of sludge requires flushing. In theory I guess if the coolant corrosion inhibitors are working there should be none... Hence the need to change it to stop the corrosion (to keep its anti corrosion properties)..
Dan
[Edited on 2/9/09 by Bluemoon]
mcerd1 - 2/9/09 at 02:22 PM
most manufactures use long life coolant these days
The ford stuff is ment to last 10 years !
britishtrident - 2/9/09 at 02:25 PM
In some hard water areas doing a complete coolant change using antifreeze mixed with tap water will do more harm than good, with normal blue/green antifreze coolants 50% changed every year and top up with 50% mixture is enough.
With orange/pink longlife coolant 50% changed every 2 years.
In modern coolants the inhibitors are so good you shouldn't get any sludge provided they are kept up to strength.
With long life OAT coolant if using a fluhing agent it should always be an acid type never old style caustic.
britishtrident - 2/9/09 at 02:27 PM
The stuff BMW are using in the MINI goes off and turns to brown smelly goo if it gets contaminated.
nick205 - 2/9/09 at 02:39 PM
interesting point on the hard water - we live in the middle of chalk downs so the tap water is usually milky to say the least.
Would it be better to buy distilled water for coolant purposes? Obviously more costly come service time, but better long term engine care.
aka Keith - 2/9/09 at 02:50 PM
Nick, I too live in a hard water area.
I use distilled water/battery water for any top ups in mine.
I buy in 5l containers from the local hardware for a couple of quid. (bargin)
Bluemoon - 2/9/09 at 02:54 PM
This has got me thinking.. Next coolant change will use 50% distilled water, after a hose pipe flush...
mcerd1 - 2/9/09 at 02:56 PM
I've got the red ford stuff in my focus and thats apparently never been changed (8 years old) and its still nice and clean - so it seems to work...
but you have to get the right ford stuff as you can't mix it with anything else
(but I've never even had to top it up yet)
there are red, blue and green versions of the ford stuff, two you can mix with each other and one you can't mix at all (I can't remember which is which)
[Edited on 2/9/09 by mcerd1]
BenB - 2/9/09 at 03:03 PM
Definately. I used the water that comes out of my dehumidifer. Essentially distilled water. It's full of mould spores but a 105deg journey through my radiator does the trick
smart51 - 2/9/09 at 03:19 PM
The stuff I've bought is premixed long life so no need to worry about hard water. The kit car coolant always came out nice and clean. It was about the longest living part of that engine.
If the cappuccino's coolant comes out clean, I've just refill with the new. Otherwise I'll flush it through with water.
02GF74 - 2/9/09 at 03:21 PM
rainwater collected in your butt otherwise a trek to wilkinsons to buy litre bottles of deionised water (is what I used - gone up to 52 p)
speedyxjs - 2/9/09 at 06:21 PM
Isnt it hygroscopic (like brake fluid)?
dhutch - 2/9/09 at 10:18 PM
Sounds good to me.
- Doesnt need to be de-ionised, just not full of chalk!
Speedy, i think its fairly wet to start of with once you've added the 50% water?
smart51 - 3/9/09 at 07:34 AM
