does the duratec engine bolt straight to the type 9 bell housing or does an adapter plate need to be fitted?
I think it uses the mazda bolt pattern, so you need an adaptor plate.
Special Bellhousing is needed, its a different bolt pattern.
and quote:
Not compatible with standard flywheel. Needs Ford Duratec lightweight Steel Flywheel - 8 1/2" or Ford Duratec lightweight Steel Flywheel - 7 1/4" Race Clutch Plate.
not a million miles away from the cost of my XE install if I worked up the courage to add it all up
, probably somewhere around the £350 mark if you
include the 3 sets of engine mounts and modded sump.
£200and
another £200
£400!![]()
[Edited on 4/9/09 by omega0684]
Thats not a standard zetec fly' as there are no timing holes on the back.
It does look like the cvh 1.8 fly' .
