Type 9 V6 - Is this right???...
gregs - 17/9/09 at 02:46 PM
Hi all,
Have fitted my spacer to my V6 gearbox and bolted back up with the pinto bellhousing, and am a little confused - the input shaft still sticks out past the front face of the bell housing.... I was expecting the spacer plate to put it in the same position relative to the front face as it is with the Pinto g'box. What is sticking out is the the non-splined section - any thoughts?? - did everyone else have this who has converted?
Greg
matt_claydon - 17/9/09 at 02:49 PM
I'm pretty sure the input shaft protrudes pround of the bellhousing flange on a normal type 9 doesn't it?
I vaguely remember my old one not sitting lfat on the ground when I tried to stand it upright on its bellhousing.
[Edited on 17/9/09 by matt_claydon]
rallyingden - 17/9/09 at 02:56 PM
My Standard type 9 sits flat on the floor on it bell housing i.e. the input shaft does not protrude. However this is a standard box not set up for V6
RD
blakep82 - 17/9/09 at 02:56 PM
when i put the vauxhall bellhousing on my type 9, it sticks out by about 10mm. don't know if that has any relevance to pintos or not, but mine does anyway
gregs - 17/9/09 at 03:02 PM
Only spotted it coz the one I've taken out sits flat and the V6 needs chocking off the floor....
flak monkey - 17/9/09 at 03:02 PM
It should stick out a bit yep.
Not much, maybe 10mm
r1_pete - 17/9/09 at 03:06 PM
My MT75's stick out about 10mm, and the MT75 and T9 are interchangable on the zetec, so I'd expect the same protrusion.
gregs - 17/9/09 at 03:07 PM
ah good - cheers flak, is sticking out almost exactly 10mm..... I'll stop worrying.
Liam - 17/9/09 at 03:48 PM
Only start worrying if it doesn't fit on the engine
