K Series in a Westfield
anthony.french@live.com - 19/9/09 at 03:27 PM
Hello All,
So I am planning to put a 1.8 K Series in my westfield. 3 questions if anyone cal help.
1. I have a standard Type 9 gearbox from a Sierra, is it just a bellhousing to get them together. I heard something about long and short input shafts??
2. And Ideas for engine mounts as Westfield don't do K Series stuff.
3. Anyone know of a K Series powered westfield? Any pics?
Thanks very much.
Anthony,
3.
t16turbotone - 19/9/09 at 03:42 PM
Stevec has a 1.8 turbo k series he is the man to talk to!!!
Guinness - 19/9/09 at 05:55 PM
I'd be looking at Caterham for inspiration. They've done more K-series cars than anyone.
Mike
omega0684 - 19/9/09 at 05:57 PM
i agree with john, send stevec a u2u, the mans a legend!
britishtrident - 19/9/09 at 05:58 PM
Don't bother with the 1.8 if its the standard 118bhp version used in the 45,75 and Freelander the 112bhp 1.6 is much more free revving
stevec - 19/9/09 at 07:11 PM
Agree, normally aspirated 1.6 will be easier to do as well. If the 1.8 donor engine has a Getrag gearbox then the crank sensor may be a problem as it may be fitted to the bellhousing rather than the back of the cylinder block.
Steve.
PS. there are a few pics of my instalation in my photo archive, I made my own mountings.
Steve.
[Edited on 19/9/09 by stevec]
anthony.french@live.com - 20/9/09 at 07:16 AM
Thanks for the responses.
Steve C,
I have a few more questions if OK.
1. How easy is the K Series to Type 9 join up? and what exactly do I need to do it, operate the clutch etc?
2. I am planning to use the standard fuel system and ECU. I understand that I need to keep the immobiliser, key etc to do this.Any change you could explain exactly whats needed as I very much confused.
3. How easy is it going to be to wire the K Series in?
4. Can I use any vintage K series ir is there a preferred option? Sounds like the 1.6 is the way to go.
Any help would be great.
Thanks,
Anthony,
Thanks and regards,
britishtrident - 20/9/09 at 01:43 PM
The usual way to mate a k series to a type 9 is Caterham belhousing, the flywheel used is the 1.4 K series and the clutch is a 190mm Ford Xflo/Pinto 1600 release bearing required istr is a Capri 1600
The K series used 3 different MEMS ECUs models with sub-variants depending on the vehicle type application as the years went by the security system became more complex.
Most of the earlier cars had MEMS 1.9.1 I know it is possible to get the security system disabled on this system and ISTR on the MEMS 2.x.x Avon Diagnostics no longer have a web site but try emailing . paul@avon-diagnostics.co.uk
ISTR it is also possible to get exchange ECUs from some reconditioners that have the security gubbins disabled.
The rover 75 with MEMS 3 had the full BMW EWS security system and has far as I know nobody has yet found an easy way of disabling it.
As an alternative Emerald wil sell you that plugs straight into the Rover MEMS socket --- I think only MEMS 1.9.x
Then of course you have the Megasquirt option.
Gary 7 - 20/9/09 at 01:48 PM
I used the v6 type 9 (long input shaft)as the ratios are better. To mate the engine and box up you need a bellhousing loads around new or second hand i used one from qed,ford clutch arm and bearing,clutch you can use ford 1.6 capri plate with the rover cover.
You need a starter motor and mounting spacer, i have a starter spare if interested.
To connect up you need the 5as rover alarm module and a length of the loom with the connectors, ecu, engine loom and key fob remote,also were the engine loom connects to the bulkhead on the rover cut a length of loom out so you can wire it in the car ,then just plug the engine in.
I havent used the 5as or fob, i had the ecu decoded (immobiliser removed) to get the engine to run is only 4 wires.
If you go for the 1.8 you will need a flywheel from a 1.6 to fit the bellhouing. If changing flywheels the crank trigger patterns vary so match up with your rover engine and ecu.
britishtrident - 20/9/09 at 01:53 PM
Follow this link --- look halfway down page
http://www.talonsportscars.com/metrocatalogue.php
Although they say it will work with MEMS 3 not all cars MEMS 3 use the 5AS security system ---- Rover 75 & MG ZT use a different system.
britishtrident - 20/9/09 at 02:00 PM
More links
http://www.automotiveelectronics.co.uk/index.php?f=data_rover&a=0
ss1turbo - 20/9/09 at 07:39 PM
There's a 1.6/Caterham bellhousing/Type 9 setup on ebay at the moment...starting bid of £375
anthony.french@live.com - 21/9/09 at 11:59 PM
Thanks to all for the responses. Tracking the caterham setup on EBAY. Although it doesnt sound like its run in a long whilel
britishtrident - 23/9/09 at 11:44 AM
I would strongly advise you create a new username not based on your email address.
