hi guys, im after coolant hoses top two connections are 30-32mm .
and the bottom needs to be 40mm one end to 30mm the the other end with a t section in the middle with the end of the t being 15mm
its pinto to polo rad.
A few years ago my local motor factors let me sit on the floor of their stores with boxes of hoses to sort through. Try asking them nicely when they are not too busy.
Similar to Dingz ^^^^
My local factors had a catalog with pictures of the shape and end diameters of each hose.
There was one that looked good for the top hose if the 90deg bend was cut off one end.
I used the 90 for the rad bottom connection. Two for the price of one. Result!
Paul G
