Evening all,
First off, I'm a complete novice at this but I've started stripping down a zetec engine from a 92 XR3i.
So far I've taken the bellhousing off the engine and then removed all the bolts around the gearbox casing and bellhousing so I can split the
two.
My problem is I can't work out how to get the clutch release bearing out and I can't therefore get the bellhousing off.
Inside the bellhousing is an arm which must push the bearing against the clutch - the arm is attached to a bracket behind the bearing by some kind of
small pin.
I can't work out how to release it ?
Also - there is only one pin on the bracket (on the exhaust manifold side) - should there be two ?
Any help gratefully received....
thanks
Paul
